Perform this procedure to disable Auto-sense on one or more ports. You also have the option to disable Auto-sense on the port but retain the configuration that the system applied dynamically. The dynamic configuration becomes a manual configuration and is visible in the show running-config output.
If you select more than one port, the format of the tab changes to a table-based tab.
You can also complete this task on the Configuration > Fabric > AutoSense > Port AutoSense tab. For more information, see View or Modify the Auto-sense Port Configuration.
  1. In the Device Physical View tab, select one or more ports.
  2. In the navigation pane, expand Configuration > Edit > Port.
  3. Select General.
  4. Select the Interface tab.
  5. For AutoSense, select disable.
  6. Optional: Select AutoSenseKeepAutoConfig to retain the configuration that the system applies dynamically.
  7. Select Apply.
